Tiburon 2.0 --> 2.0 Turbo
Old Dec 25, 2005 | 11:20 AM
idremel's Avatar
Hi. I have garret turbo from Hyundai Scoupe 1.5T! Is that turbine small for Tiburon 2.0 16v? And do I must change my stock pistons with high pressure pistons?
Old Dec 25, 2005 | 12:49 PM
TiburonWao's Avatar
You better do a search before said something else....
Topic has been talked evry month....
Before thinking about pistons, you better get some info about "fuel delivery"....
Old Dec 25, 2005 | 01:47 PM
brian01tib's Avatar
If anything you would want low comp pistons. I havent had one but the turbo seems like it would be to restrictive, and heat up alot. Better off getting something like a turbo from an evo (twin scroll I believe) or other mitsu if you want to use a turbo from another car
Old Dec 26, 2005 | 11:56 PM
Denisst99's Avatar
the scoupe t15 turbo has problem pushing enough air for the little 1.5.. so for the 2.0 it would only be worst
