How High Do You Rev?
Old Nov 29, 2005 | 07:54 PM
12SecRD's Avatar
Just wondering how high you rev your engines to and what mods you have.
Anyone know how much is a safe RPM on a Stock Head with Cast pistons?
I am reving to 6700 RPMS and would like to be able to shift at 7000 because the car just wants to pull way beyond it but I Don't to rev to 7000 if its going to mean trouble.
Old Nov 29, 2005 | 08:13 PM
what would have to be done to rev that high? I remember someone saying you could if you used the 1.8 crank but Im not sure. id love to be able to rev that high when I get my turbo in
Old Nov 29, 2005 | 08:48 PM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
I don't think it's safe to rev that high personally. The higher you rev the faster you wear out your parts.
I'd be careful, you're boosted so of course you're gonna wanna push it that much harder at high RPM's. maybe (gets ready to run) turn down the boost a little so you can get the most out of the turbo. (ducks, and runs, is around the corner before Gary can start his b!tch slap)
Old Nov 29, 2005 | 09:33 PM
Airborne's Avatar
Vehicle: 01 Tibster
Here in Korea, a lot of us (myself and Madjohn included) set our rev limiters to 7200 rpm. The stock beta can rev reliably all the way to 8000 rpm for short periods of time. 6800 is safe without ECU tuning
Old Nov 29, 2005 | 10:49 PM
JH~Tibby's Avatar
If its stock keep your RL stock...But with my turbo I let mine run all the way to 7500. It can go to 8 but I stopped it at 7.5. If Im at the track Ill kick up my boost and let it run to 8 but that is ONLY at the track.
Old Nov 30, 2005 | 09:03 AM
I should be able to reset the RL with the PRS4 right? And it makes sense that you wouldnt want to rev that high all the time
Old Nov 30, 2005 | 09:24 AM
JonGTR's Avatar
^^^Yes you can set it to whatever you want.
If you don't want to rev it that high all the time, then just don't floor it. dunno.gif
Old Nov 30, 2005 | 10:56 AM
2kShark's Avatar
Where are our rev limiters? I have an automatic and at WOT in 1st, I will bounce off the rev limiter it seems somewhere around 6,700 (my tranny has problems, hopefully it's just the kickdown switch)
Old Nov 30, 2005 | 01:38 PM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
I believe stock rev limiter is at 6750 RPM
Old Nov 30, 2005 | 02:10 PM
Tibminn's Avatar
Ill be turboing my car this winter, but will only be running low (~8psi) boost. I wont have any piggy back or tuning system so is there still a way I could move the RL? Would it be safe without any specific tune? Thanks
