Fuel Pump Needed?
ok Im probably going to be setting up a custom turbo kit over this winter and maybe a bit of spring and i pretty much know everything Ill need to safely run 7-8 psi. I know most people say get a fuel pump and an fmu, but i have some 33lb injectors layin around and I was wondering if I had any options with those on such low boost. If I could use those, would I still need the fuel pump?
Also, is the tsi fuel pump the same as the gsx? and what gen are the good ones again... i could look it up but
Im lazy
Im lazy
i got a holly 255 lph one, its for an 93 eclipes and you dont have to cut the jack at all, you will have to yse cable ties or wire to sucure it to the bracket
for the tiburon, fuel injectors are a ford rochester type design injectors.
top feed, high impedence.
Denso designed fuel injectors did not fit in my car.
I purchased my 60hp fuel injectors from this dealer www.capa.com.au
If you're going to be tuning your car for 7-8psi, it may not even need the fuel pump & injector upgrade.
When my car was being run on the Dyno, fuel supply was leaning out at 6000rpm, 16psi.
upgrading the fuel pump to 255LPH and 60hp injectors fixed the problem.
I bough some of my parts from Racing Edge Performance.
website : http://www.treperformance.com/FuelPumps/
The stock fuel pump only supports around 180whp. So, yes, get some kind of bigger pump.
