First Megasquirt Powered Tiburon Ever Is Alive Hahahaha
Well just started the tiburon today for the first time in 6 months again. This time is is powered completly by a Megasquirt Standalone ecu. I will be working on it again tomarow as I found a coolant leak but after 6hrs of trying to get it running one rogue setting turned up to be the culprit. Long story short the car would start then in 3 seconds die no matter how much fuel I would add or sub. After changing the 1 setting It fired up like usual then kept running for over 5 min WHOOT. Will keep you updated on the progress. Oh by the way for anyone interested in the MS I have less than 400$ in a completly new unit. I also recomend dealing with RSAUTOSPORT as he has treated me extremely well when i had some problems and kept in excellent touch. I will do a writeup on this later but anyway Im off to bed.
damnit, you beat me to it. ive been reading up on that thing for a good couple months now, and it is awesome. i will be purchasing one for when i get boosted, and using it to only run secondary injectors. you using it for fuel and spark?
etiher way, good shit man.
no can do. gotta have emmisions man. and im not swapping it out everytime i need to test the car. i know it wont be utilized to its full potential, but its still cheaper than anything else.
