Water Line Feed For Turbo.
Old Mar 6, 2006 | 01:18 PM
yamaha's Avatar
Vehicle: 2000 Hyundai Elantra
I've searched and came up with nothing. The T28 turbo I will be using is both oil and watercooled. Ive decided to tap into the lower and upper radiator hoses for the coolant connection. My question is, is it the lower or upper hose that feeds into the engine. I am assuming the lower one feeds into the radiator and the upper radiator hose is a return to the engine, but I needed to double check.
Thanks,
Sean
Old Mar 6, 2006 | 01:48 PM
youre going to tap into the HOSES? there has to be a better way than that. anywho:
i think this picture is int he engine bay too.
Old Mar 6, 2006 | 01:58 PM
JonGTR's Avatar
Get two 3/8" barb fittings to put on your turbos water ports. Then run two hoses over them and the water ports for the throttle body on the back of the head. Instead of doing the throttle body bypass, your actually using them for your turbo.
