Fpr Adapter
Old Dec 11, 2005 | 11:31 AM
well i was surfing ebay cuz the forum is dead right now and i came across this
its a adapter to connect the fuel rail to a fpr
would that work?
also
would it be safe since you cant really use -AN line?
Old Dec 11, 2005 | 11:40 AM
now i gotta find another set of stock injectors and a stock fuel rail...
Old Dec 11, 2005 | 12:35 PM
JonGTR's Avatar
There are several ways of making one dirt cheap.
One way is to take your fuel rail and the fitting over to a welder and have them weld it on. Shouldn't cost over $15 total.
Another way is to find the plate that goes on the intake side of the fuel rail from a junkyard. Cut off the metal tube from it, then weld on a fitting to that. This is the way I did it so that the rail stays in one piece.
Old Dec 11, 2005 | 12:37 PM
12SecRD's Avatar
All I did was mine was tap it
Old Dec 11, 2005 | 01:55 PM
LarryMcFly's Avatar
OR, you use a b&m command flo for honda. They fit perfectly. You just need to cut your oem fpr in two and install the b&m unit. Takes 5min, no need for a flange on the fuel rail, no need for a braket to mount it somewhere else. The unit is cheap, around 60US$, 80US$ with the fuel pressure guage that also fits our fuel filter unit. The B&M frp is, by far, the best bang/buck for our cars.
Old Dec 11, 2005 | 05:08 PM
Denisst99's Avatar
tap your stock fuel rail for 3/8 NPT then you'll be able to use what ever fitting/hoses you want
will cost pennies to have it done at a local machine shop
