Project Beta2
Vehicle: 2003 hyundai accent beta swap
ok as some of you know i wanted to make a beta 2cvvt rev to 9000rpm, but all you guys said that the cvvt was pointless so i went on webtec and click on the online class room and read all about the cvvt and you guy were right. so i went out and buy a 2003 beta2 ( for more info and pic project beta2) now i would like to know if or how can i put the the 1.8L crankshat in it??? and also i want if i keep the 2.0L but put the 1.8L pistion in what will my compression be at??? is it true it will be at 11:1???
QUOTE (Casper @ Nov 10 2005, 12:04 AM)
The 1.8 crank will fit perfectally. The only thing you need to change out is your rods. You will need to buy a custom set.
will these rod work http://shop.hyundaiperformance.com/shop/it...p?i=HWA_CRB0001
and the motor is coming in a 2003 accent
Sorry, by custom, I mean special order. You will either need a shop to take measurements for you, or if you feel comfortable, take them yourself.
The easiest way is to install the 1.8 crank with a 2.0 rod and piston. Take the piston up to TDC and measure the distance from the top of the block to the top of the piston.
ie. Say you get 3mm. Call up crowler and explain that you need rods for a 2001 hyundai tiburon but you need them made 3mm longer.
QUOTE (anthonyfa18 @ Nov 10 2005, 07:09 AM)
That's gonna be a beast!!! Good luck again man!!!
^^^ I bought my spare beta1 before I knew what exactally I wanted to do with it wink1.gif
From HP
Now why would you make sure it runs before you tear it appart? I mean come on!
From HP
QUOTE (thegrim @ Nov 10 2005, 08:25 PM)
looks nice. have fun. dont ya think u should make sure it runs first? before adding heavy mods to it, such as internals with compression differences and electric such as ignition (msd). the swap itself may stump you a bit. IMO, get it in and running before heavily modding it.
