Qs For Boosted Guys
Vehicle: Elantra HD / 2007
Interesting what setups do you have?
1. What turbine?
2. How many psi?
3. How much whp?
4. What is your compression ratio? (if lovered - how?)
5. On which gas are you running?
6. What do you have for fuel manajement (injectors, FMU, piggyback, pump....etc)?
1. What turbine?
2. How many psi?
3. How much whp?
Guest
Posts: n/a
Speedfactor Modified Xtreme setup..
t3 super 60 turbine
~8 psi
no clue on whp, but she picks up and goes very nicely. ~190whp maybe
stock compression 210-209-210-208 to be exact
93 to 94 octance when available.
running emanage with all harnesses including ignition and injector harness utilizing the MAP sensor for boost. have dual fuel rails.. stock rail has stock injectors running on stock fuel map, boost rail has 340cc injectors that only kick in under boost. Aeromotive Fuel pressure regulator. walbro 255hp fuel pump.
although, i am going to be selling some of this setup to upgrade to
GT30, or GT40 turbo (ball bearing, supports alot more hp)
~16-18 psi
hopefully 350+WHP
forged 8.5:1 pistons, cryo treated rods
94 octane
still going to run same fuel management.
t3 super 60 turbine
~8 psi
~16-18 psi
hopefully 350+WHP
94 octane
Turbo - Holset hy35 9cm turbine
psi - 20 as of now 28 on race gas
whp - by track time on 15psi around 280-300
com - 8.5:1 wiesco pistons with head milled 2 times so 9:1?
gas - 91 for 15 and 93 for 20psi
Eng - greddy emanage sysetem with ignition setup and 4 additional injector for 119lb hr of fuel walbro 255 will be using 2 of those.
