I Need To Change My Map Sensor?
Old Feb 7, 2006 | 08:37 AM
fastuning's Avatar
Vehicle: Hyundai tiburon 1.6 TURBO
hi, i have install my turbocharged and my car goes very good.....but now i´m going to install a APEXI AVCR to control the boost and i need to buy a 3bar or 2,5bar map sensor for the apexi but my question is....
the MAP sensor of the car i need to change it also? or only the apexi map sensor?
Old Feb 15, 2006 | 04:34 PM
TiburonWao's Avatar
mmm The OEM MAP sensor read at 1 BAR maximun....
I really dont know about the APEXI AVCR... let me search first....
But If you want to go HIGH Boost.... you better think on any other ECU Manage....
Old Feb 16, 2006 | 01:32 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
hmm, I thought stock MAP is 1 bar absolute pressure.
If you have 1 bar (14psi) boost than you need at least 2 bar MAP (1 bar athmospheare pressere and 1 bar boost).
Old Feb 16, 2006 | 03:37 AM
Airborne's Avatar
Vehicle: 01 Tibster
The Apexi AVC-R is only a boost controller. It's probably the best on the market. I've got one and it's awesome, change boost on the go and it will prevent deadly boost surges.
You'll need a better MAP sensor for your ECU. I'd recommend a 2.5bar- that's what I'm using. What sort of fuel management are you using?
Old Feb 16, 2006 | 06:42 AM
fastuning's Avatar
i´m using for the fuel management an APEXI SAFC2 and wideband sensor to regulate the air/fuel ratio....
i´m running at low pressure now...
in the future...maybe i talk with you AIRBONE for a 16 BITS ECU
