Megasquirt
Hi...
Does anyone knows anything about the Megasquirt?? does it works in Hyundai??? any problems or good opinions???? What about installation???
I'm planing to buy the Megasquirt II... but I'm looking for some recommendations...
Thanks..
Thanks..
It's the same principle as the PRS4. If you couldn't get anyone to install that, then you're not gonna get the MegaSquirt to work.
Guest
Posts: n/a
I think the install was fairly easy. Adam (t4turbotib) has the megasquirt and the emanage ultimate piggybacked onto it, resulting in Ultimate ease of tuning, and tuning ability. He might be able to make you a plug and play unit, no splicing, just plug and play, he made one for me. He also may be able to help you out with some base maps, which would help you out, beings you have no other way of getting help over there.
PM him and see if he would be interested in helping. I am sure that he would. Hes a great guy, fair prices on stuff, and has always been there to help me when I was in need.
The fact is that the PRS4 nobody here knows how to install it.... it happen the same problem in the ignition...
but the the same mechanic have installed several Megasquirt here in my country.....
With the PRS4 I lost a lot of money.... even I'm selling it on ebay for 400 shipped...
so sad....
I need some fuel managment as soon as possible....
so sad....
QUOTE (TiburonWao @ Mar 28 2006, 01:41 PM)
so sad....
so sad....
It's the fact that the stock ECU has internal ignitors whereas the PRS doesn't, and won't amplify the signal enough to fire the coils. Any experienced shop should know about that. I don't claim to know a lot about it, but it's not something unknown to a true mechanic.
Like I said, if they couldnt install the PRS, then they're not gonna be able to install the Megasquirt either. It will have the same problem with the ignition. And they'll probably be lazy about it and send you home just like last time.
We're trying to figure out a cheap and easy fix for it right now. So if you want to wait, then it's up to you.
JGTR-
Why not use coils with built in ignitors? Leading Coil Packs off RX7 Turbo's have the ignitor in them (trailing packs do not). That way any Aftermarket ignition system should be able to fire them
Or, buy a Haltech or Motec Ignitor (not cheap) and wire it in. There's only 7-8 wires, so you should be able to use them with a signal from any aftermarket ECU.
