2 Blow Off Valves Instead Of 1
Old May 7, 2006 | 07:11 AM
dvanderk's Avatar
Has anyone heard two blow off valves on a car instead of one?
Old May 7, 2006 | 07:50 AM
brian01tib's Avatar
Why would you want that? Seems like just more money, everyone has been fine with just one.
Old May 7, 2006 | 09:20 AM
JonGTR's Avatar
That Korean guy on NT.
Old May 7, 2006 | 10:03 AM
dvanderk's Avatar
changes the sound to more unique
Old May 7, 2006 | 02:06 PM
IJSTBRNDU's Avatar
if your running over 40 psi it a good idea to use 2 but until them...no good reason to
Old May 8, 2006 | 01:47 AM
01blacktib's Avatar
yeah, over 40 psi, you're prolly full race by then, so it'd help. other than that, two blow off valves, are necessary in twin turbo applications, such as a supra or so. if you want a twin turbo for the tib tho, its most likely not going to get you huge gains. and if over 40psi of boost, you can get a bigger blow off valve, its just more efficient
Old May 8, 2006 | 07:00 AM
dvanderk's Avatar
Well what i was wanting to aim for was sound. Would the spring still open for 2 BOV if I y split the vac line at say 10-15 psi?
Old May 8, 2006 | 07:39 AM
01blacktib's Avatar
it would most likely still open, but i think you'd just have the same sound, because if they are goin off at for example 50db@1m, and its times two, it won't make it 100db@1m. so really, it wouldn't do anything but impress people who don't know much about turbos. it'd be good, IMO only if you had twin turbos, and then had each BOV specified for each turbo.
Old May 8, 2006 | 07:50 AM
dvanderk's Avatar
The Greddy TYPE RS and the TYPE s, have these sounds I like.
When I ran the TYPE S it had a loud wistle and the type RS had a woosh sound to it, I liked how they both sounded.
Old May 8, 2006 | 07:20 PM
NemainTib00's Avatar
Give a look at the BOV's on 3sxperformance.com The're all bout 3000GT's and Stealths but they make their own equip and a BOV is universal. Check out the Type-H-RFL and Type H-34 both have sound clips (open hood, driveby and incar - 1 clip) just ignore the engine noise.
Hmmm, I think I'm giving away a secret 02.gif, but it's for our family so ok...Just I have dibs on the custom port and cliped 368 turbo tongue.gif
