Dsm Injectors
Old Jun 16, 2006 | 12:14 PM
tblakea04's Avatar
Vehicle: 01/Hyundai/Tiburon
i had no clue about this but figured id ask because some local DSM owner is selling these injectors for $50- DSM 450cc blue top p&h injectors- and just wanted to know if anyone knew if they would fit good?
Old Jun 16, 2006 | 12:20 PM
JonGTR's Avatar
I believe they will fit, but they will not work. They're low impedance, and we use high.
Old Jun 16, 2006 | 01:29 PM
Jay-M's Avatar
Vehicle: 01 Tiburon
You can convert low impedance in high by using a resistor box... but it just complicate things!!! stick with the ones directly compatible with our cars
Old Jun 16, 2006 | 03:35 PM
tblakea04's Avatar
ok thanks was just wonderin cause he was selling them for $50 but ill just wait and get the others when im ready
Old Feb 17, 2010 | 06:12 PM
zerogrips13's Avatar
Vehicle: 96 accent
so will these fit ive yet to find a definate answer... a resistor box is not a problem will the injector fit without modifications or with and what...
Old Feb 17, 2010 | 09:26 PM
ZKend's Avatar
yes they do fit. i have some dsm 440s out of a talon Tsi that ill be most likely using. or i might pick up some FR 440s.
but yes..they fit
Old Feb 21, 2010 | 01:10 AM
Denisst99's Avatar
the top o'ring size is much smaller...
and the bottom o'ring is WAY different..
might work with some extra work, but not worth it
Old Feb 21, 2010 | 07:08 AM
JonGTR's Avatar
IT's just sooo much easier to find some green tops. They're cheap and found everywhere.
