Turbo Questions
Old Feb 7, 2006 | 12:25 PM
DaytonaTibby's Avatar
Ok, Ive searched alot and found that in addition to my turbo I will need some bigger injectors, a fuel pump, a rising rate fuel pressure regulator, and a remapped ecu of some sort. I only plan to run 7psi and want to stay as inexpensive as possible. I just need some Verifications on this:
Universal Bosch injectors will work?If so what size?
A Fuel pump from a 95-99 Eclipse will work? Where can I get one cheap? Anyone selling one?
Will this RRFPR work?
http://cgi.ebay.com/ebaymotors/Rising-Rate...sspagenameZWD1V
If I get a RRFPR will I need a FMU?
Can I get away with just an FMU and not a RRFPR?
Has anyone worked with a MegaSquirt ECU? With this I should be able to control injector pulse width, and be able to tune just about anything without a dyno.
Again Im trying to go with the minimums. I plan on 7psi and about 220HP. If there is something on here I dont need please let me know. Im on a college budget!
Suggestions are welcome!!!
Old Feb 7, 2006 | 01:34 PM
Tibminn's Avatar
Ive heard many, MANY good things about megasqirt. Unfortunately I havent heard of anyone using it on a tib yet. If (most likely when) I decide to up my boost I will highly consider going the ms route.
nevermind bout not any tibs using it, I just read 01importsharks post... haha
Old Feb 7, 2006 | 01:40 PM
Where did you get your Accel Injectors. I cant find any for cars other that Honda and Acura.
