PDA
View Full Version : Turbo & Supercharge (Forced Induction)
Pages : 1 [2] 3 4 5 6 7 8 9 10 11
  1. Usedturbos.net
  2. Hot Tanked Block
  3. Car started to have BOV flutter
  4. Boost Leak Tester
  5. Intercooler Temp Question
  6. misfire in 1,3,4,and random cyl. need help!!!
  7. .68 vs .96 housing, detonation
  8. How loud is your turbo spool?
  9. Any boosted betas still using a Civic radiator?
  10. Tricks to getting fuel fittings on the hose
  11. Is my oil pressure low?
  12. Why are hypereutectic pistons bad for boost?
  13. Whats a good way to strip paint off intercooler?
  14. Have you ever seen any really bad turbo installs?
  15. NGM Superchargers
  16. Other cars turbo manifold on a Tiburon
  17. Maf sensor flange question
  18. Could too much back pressure cause tuning problems?
  19. Question about electronic boost controllers and spring pressure
  20. look legit to you guys?
  21. Is seafoaming bad for cars with a turbo?
  22. Question about fuel octane
  23. Dave: 2 Wires on the TF10?
  24. air filters installed directly on compressor inlets
  25. How exactly should the throttle be applied?
  26. Are turbo timers normally this cheap?
  27. anyone running high psi on decomp plate?
  28. help?
  29. decompression plate question..
  30. Turbos everywhere
  31. Exhaust a/r question
  32. Vid of my BOV
  33. supercharger for rd2
  34. Turbo Project. Gearbox questions
  35. Oil feed line from the block
  36. exhaust sound
  37. exhaust sound
  38. Carbon Buildup on Turbo
  39. Straight Bolt on supercharger
  40. Ideal Turbo setup for Autox?
  41. Everyone who has a turbo - LOOK HERE!
  42. Boost controllers
  43. BOV & wastegate springs
  44. vacuum. lines
  45. Good size ic?
  46. tib turbo dyno
  47. Any of you agree with this statment about rebuilding your turbo
  48. Is there any boosted A/T owners on here?
  49. the oil feed line
  50. turbo question
  51. Anyone with a big trubo on a an RD?
  52. Premium or regular for 2.0Ts
  53. Which is more common in the car world
  54. Ok please settle a bet
  55. No boost in neutral. Normal?
  56. walbro fuel pump questions
  57. intercooler piping
  58. Do you regret going turbo?
  59. Quick Spool Valve?
  60. Need a turbo timer
  61. Adding forced induction to a high mileage motor
  62. Power washing FMIC
  63. Wastegate Spring Size?
  64. How many use titanium intake valves?
  65. How do you guys know what size injectors you need?
  66. Exhaust piping
  67. Banjo bolts
  68. restrictor location
  69. Turbo people – what compression do you have?
  70. High oil pressure pumps
  71. Cleaning a turbo
  72. Ramhorn manifolds
  73. New turbo, old gas
  74. White LED tube to light up FMIC
  75. Blow off valve question
  76. Blow through vs. Draw through MAF
  77. Ball bearing or journal turbos
  78. Bar and Plate vs Tube fin vs Delta fin
  79. Dump tubes
  80. vacuum line
  81. Turbo motor beta 2.0
  82. atmospheric wastegate vents
  83. Is it a bad idea to
  84. Wrapping the DP
  85. 4g63t valves
  86. Is it normal
  87. Hard lines for oil return
  88. Grand National Turbos
  89. Detonation question
  90. all most there
  91. Breaking in a new built engine
  92. butt weld pipes or have them expanded?
  93. Best way to drill into oil pan
  94. deep tone exhaust
  95. pulley options for supercharger
  96. need help finding downpipe
  97. Tuning software
  98. Anti-lag
  99. what injector size do you recomend?
  100. Bolt-on Wastegate Flange?
  101. Thoughts on this black intercooler
  102. 2 questions about blow off valves
  103. How good are the stock Evo FMIC’s?
  104. What controls boost? (semi-rhetorical)
  105. Who makes good tubular manifolds?
  106. Question About Turbo Blankets
  107. Boost by gear
  108. what is a wastegate vent?
  109. Importance of ignition advance in high boost applications?
  110. internal wastegate turbo/external wastegate header
  111. What size turbo came in the Alpine kits?
  112. MAF question
  113. Turbos at high altitudes
  114. HELP FUEL
  115. Cooling pistons with oil squirters
  116. How much energy or power to spool a turbo?
  117. Turbo Measuring
  118. Is this the AEM i need
  119. Does higher compression spool a turbo at a lower engine speed?
  120. Non mandrel bent tubing for hotside
  121. What should happen if no boost line(vac line) is not hooked up to wastegate?
  122. alternator/downpipe
  123. Turbo shaft play
  124. Hot air vs cold air
  125. Airflow question
  126. N00b question
  127. When will this turbo spool?!
  128. what a/r
  129. FIC issues (again!)
  130. Oil cooler turbo question
  131. Whats the next best upgrade for Gen Coupes?
  132. Jet hot
  133. Best clamps for couplers?
  134. turbo's affect on exhaust sound
  135. Anyone with water cooled turbo?
  136. Dual exhaust on a turbo
  137. Car started now won't
  138. Throttle body size
  139. Boost Addicts - Do We Need a 12 Step Program?
  140. How a Turbo is Made
  141. How to inspect a used turbo?
  142. tightening of bov
  143. Twin scroll turbo systems
  144. need FIC fuel map for 7-8psi
  145. Quick question
  146. New oil seals
  147. Whatever happened to madjohn?
  148. Turbo compressor map java calculator
  149. Boosting to 8-10psi
  150. Best product to make an FMIC shine
  151. What would I have to upgrade if I bought this kit
  152. Question on Custom piping
  153. My Engine Build (Pics Inside)
  154. What exactly are bars?
  155. Do you lose gas mileage after installing a turbo?
  156. Tial Wastegate
  157. Bov???
  158. Air to Water intercooler for genesis coupe
  159. oil pump drive gear
  160. i THINK..... I found the right turbo
  161. Narrowing Down Turbos.......
  162. turbo size
  163. Just got a Tial wastegate...question
  164. Turbo question
  165. Oil fittings, lines, etc questions
  166. MegaSquirt users
  167. Walbro fuel pump question
  168. Dynamic and Static Injector Question
  169. Blow Off Valve question
  170. Whos built their own supercharger and installed it
  171. What are common reasons a turbo starts to fail?
  172. Boost controller question
  173. Do you need an intercooler if you're under 8 psi?
  174. Detonation and EGT.
  175. Mid Mount Turbo
  176. Heat from the turbo effecting battery performance
  177. Turbonetics T3/T4 .63 A/R
  178. Oil catch can setup im working on
  179. Secret to removing injectors from fuel rail?
  180. In need of an AEM FIC base map
  181. recirculating BOV
  182. Fog lights and intercooler piping
  183. How often should you retorque new head studs?
  184. Hydrolocking
  185. Any gen coupe owners running alcohol or meth injection yet?
  186. Precision Turbos
  187. k spec head gasket
  188. Twin Turbo Beta
  189. How much power can you make with stock fuel lines?
  190. 7psi whats needed
  191. Beta swapped and boosted accents
  192. Safe to go 4000 miles between oil changes
  193. valve spring removal.....
  194. Cams
  195. GT30
  196. Polished injectors
  197. Vacuum blocks
  198. How long have you been boosted?
  199. Building a turbo on a college budget
  200. Dual tuning maps
  201. cometic head gasket
  202. Gen 3 S145 1.6 Turbo
  203. What are the chances of blowing motor dyno tuning?
  204. FIC issues
  205. Oil-less turbos
  206. HX35 diesel turbo
  207. Turbo adapter
  208. New Project Car!!
  209. Using non synthetic oil
  210. Got a ticket for my BOV
  211. Tuning and spooling
  212. Changing the flow rate of the stock injectors
  213. Need wideband LC-1 Help
  214. Bigger fuel lines
  215. Plasti-dipping FMIC
  216. What size exhaust piping do you FI guys have?
  217. Failing state inspection
  218. turbo return line?
  219. Does it make sense to stay NA because of there being so many problems associated with FI?
  220. At what RPM do you hit full boost by?
  221. Part of the F/IC crowd
  222. Would the alpine supercharger even be worth buying?
  223. anybody running AEM truboost?
  224. Connecting turbo timer to an alarm system
  225. Question about overboost
  226. 2 intercoolers at the same time!
  227. 6262 ball bearing -3an oil feed line
  228. 440 innjectors fuel press
  229. How did everyone learn about turbos?
  230. Aftermarket fuel rail
  231. Will one fan be enough to cool a FI engine?
  232. Midnight Motoring Turbo Kit for Feedback
  233. aem fic wiring
  234. aem fic
  235. Max Power made with Log Manifold?
  236. no weld o2 clamp
  237. i really want boost
  238. .36 a/r housing
  239. Junkyard Turbo List
  240. Aluminum radiator
  241. $22 HKS BOV?
  242. Mega Squirt starting point for New tuners
  243. Will greddy emanage work as a piggy back on rd?
  244. Wastegates - Tial vs HKS
  245. When idiots know nothing about turbos
  246. decompression plates
  247. turbo blanket or heat shield?
  248. Intercooler on a N/A car
  249. Does an intercooler make a forced induction engine more effiicient, or just more powerful?
  250. turbo on auto?
