When will this turbo spool?!
Old Jan 16, 2012 | 12:57 PM
tribaltib's Avatar
Vehicle: 2000 Tiburon
Default When will this turbo spool?!
Here is the turbo, it is a garrett t3/60-1 turbocharger. Here are the stats:
COMPRESSOR SPECS:T04S housing
flow: 61 lbs/min 781cfm
.70 A/R housing
60 TRIM wheel
TURBINE SPECS:T3
.63 A/R housing
HIGH FLOW 76 TRIM stg 3 wheel
oil lubricated centersection.
for use with external wastegate.
COMES STANDARD WITH 360 DEGREE THRUST BEARING!!!
supportable of 575whp!
With those stats, I assumed the turbo should start spooling at about 3000rpm and hit full boost at about 4000rpm. Does that sound right? Correct me if im wrong.
Old Jan 16, 2012 | 08:22 PM
slow 2K2GT's Avatar
Vehicle: 2003 Hyundai Tiburon i4
If it were a BB turbo than the spool would be around that quick however with the journal bearing you may be in around the 4500rpm range for full, strong spool.
Old Jan 17, 2012 | 12:34 AM
tanc's Avatar
Vehicle: 1997 Tiburon
Why don't you just by my ballbearing gt40 and be happy. https://www.hyundaiaftermarket.org/f...00whp-capable/
