Oil fittings, lines, etc questions
Vehicle: 01 Tiburon
Hopefully I'll be finishing up my build in the next few months - I'm trying to tie up a few loose ends but the big things left for me to buy/install is the oil stuff and then fuel management. A little info:
New Garrett t3/t04e turbo (60 trim, .63 AR)
Walbro 255lph pump
Tial BOV
Tial 38mm wastegate
Ebay generic black FMIC
I have all the piping too
Bought to get some brand new 550 cc injectors from friend.
What do I need in terms of oil lines/fittings? I know I need to tap into the oil pan but beyond that I'm not sure what all I'll need. Anybody have any advice? Is there a line kit I can buy?
Walbro 255lph pump
Tial BOV
Tial 38mm wastegate
i offer all kinds of 'kits' for lines.. the FPR/fuel rail kit.. feed lines, return lines..
oil cooler kits.
what 550cc injectors did you get? will they drop in?
what type of piping did you get? couplers? clamps? manifold?
here is pretty much a parts list in my store for everything you need.
turbosocks tiburon kit
oil cooler kits.
Vehicle: 1998 Elantra
i wouldnt just tap into the pan, i would also weld it so there is no chance of leaks, i would weld on a 10an fitting for the turbo oil drain, as for the oil feed, theres some freeze plugs on the block that you can take out and run a stainless braided line to the turbo, oh and weld that 10an fitting as high as you can on the pan, too low and expect problems, my oil wasnt draining properly because the first time i had it the fitting was too low.
