Failing state inspection
Old Jul 12, 2011 | 02:39 PM
NJ_DRIVER's Avatar
Vehicle: 2004 Tib I4
Default Failing state inspection
Would adding a turbo kit to your car make you fail state inspection in any way? Even if you dont have any CEL's?
Old Jul 12, 2011 | 02:42 PM
turbosocks's Avatar
depends on the state and the type of inspection..
if they just scan for CELS, should pass if there are NONE
if they just do a idle rev sniffer and your off boost maps are the same as stock, should pass
if they do a visual and more comprehensive inspection it may not pass.
radu passed inspections in Mass. with his turbo tib.
