valve spring removal.....
ok ive tried to remove theese badboys its a beta 1, cant use the spring compressor cuz the valve springs are not overhead, the hammer trick dont work, how do you guys remove theese things?
ya i bought one but the certain one i bought was an overhead spring compressor, didnt work i dont know where i can get one of theese? anyother ways to do it without the special tool, btw head is off building the motor ground up
Vehicle: '14 Ford F-150
You need this style:
http://buy1.snapon.com/catalog/item....re&dir=catalog
Doesn't need to be from Snap-On, any brand will work. The important part is that it works by grabbing the spring coils and pushes down on the retainer.
Oops... Yeah, you need this style:
BTW, that's the Hyundai part number for the tool.
http://www.matcotools.com/catalog/pr...NG-COMPRESSOR/
thanks guys, you guys are awesome, btw i got one valve out today using a tool i made from an o2 sensor socket, worked ok, then i was trying to remove the valve guides not so easy, i ended up breakin the end of it where the combustion chamber is );;
