HELP FUEL
Vehicle: 01 Tiburon
HELP FUEL
CAN I use a blox fuel management for my 01 tiburon turbo i just want to go to 10psi right now im running 7psi and at wot its leaning out .. i have 440 green tops and 255 walbro for fuel if i can use the blox what ratio do i need thanks
http://www.horsepowerfreaks.com/part...t_Units//15179
need to know asap so i can get my car going thanks
Vehicle: x3
+1 what are you using to tune and adjust fuel now? FMU's were popular several years ago. Now, a good rising rate fuel pressure regulator would be more recommended (rrfpr). There was always controversy of raising fuel rail pressure past 80-100psi. figure with a FMU, 10psi with an 8:1 or 10:1 on top of your base fuel pressure wouldn't be considered ideal.
Vehicle: 01 Tiburon
i only have a fuel pressure regulator right now that i have set at 40psi and its fine as long as i dont get in to it if i do it gos lean...
Vehicle: 01 Tiburon
this is the one i got it will be here on the 21st http://www.horsepowerfreaks.com/part...Universal/4594
and i got this Recalibration kits Fuel Management Units - Recalibration Kit Assortment ( 4:1, 6:1, 8:1, 10:1, 12:1 )
Vehicle: x3
40psi and 440cc injectors, any fuel tuners (like an AEM/SAFC/DTEC/SMT)? also what brand is your wideband air fuel gauge?
a quick suggestion, potentially create one thread and call it my turbo build questions then put all your questions into it so we can follow all of your questions. seperate threads make it difficult to figure what you're up to.
