Boost Leak Tester
Old Jun 15, 2012 | 11:28 AM
terjit's Avatar
Vehicle: 1999 Tiburon FX
Default Boost Leak Tester
With out putting the car on a dyno and hooking up the ecu, how can you tell if you have a boost leak somewhere?
Old Jun 15, 2012 | 02:02 PM
alice6's Avatar
plug just after the turbo and before the throttle body, hook up an air fitting or valve stem to one side and pressurize it. use soapy water to find leaks.
