FIC issues (again!)
FIC issues (again!)
Having issues with the fic. Re-made the harness with longer leads, hooked up to the ecu, idles fine, but almost stalls out when i give it some gas. Also, I have tried the 104,107, and 110 hex, same thing.
Furthermore, when I try to log, the fic isn't found, but will work on the reflash.
Not sure what is going on.
Vehicle: 2003/Hyundai/Tiburon
Sounds like a hardware issue to me. I'd send it back to AEM if its under warranty. If its not, well then your SOL. It could also be your injector response time is set wrong. You need to make sure its set right for your injector type.
