Is this the AEM i need
Vehicle: 01 Tiburon
Yes. 30-1910 is the FIC you are after. You'll want to hit up a pick n' pull to make yourself a harness to work with unless you are good at soldering in tight places... Really tight places.
I ended up grabbing mine up to just under the speedo to make sure I had enough wire. You'll want to grab the ecu too, to solder the wires onto. Then follow socks' connecting diagram. You can find it in his vendor forum.
