Aftermarket fuel rail
Stock fuel rail will support over 450whp.
Tap the stock rail holes using a 3/8" NPT tap. Then you can screw in whatever fitting you want.
You cannot hang an Aeromotive FPR on the end. It must be mounted or supported somewhere else. The weight will crack the cast aluminum rail.
I built an aftermarket rail just because I broke a couple stock ones. lol
No one makes a custom rail, Jon tried to do a group Buy once, but i think there wasn't any interest.
As you can see with Turborons car, thats how most people do it. I have done upwards of 13 kits that way so far without any issues.
I usually have a stock pile of beta fuel rails, but recently ran out. If you are interested in one thats tapped and painted for your application, feel free to contact me. I can offer everything from just the tapped/painted rail to the entire system with FPR, lines, fittings, all ready to bolt on.
There is no need for an aftermarket fuel rail for the Beta though as it can flow more power than anyone will ever throw at it.
https://www.hyundaiaftermarket.org/forum/index.php?/topic/60680-eclipsemtl-and-iheartmyrd-fuel-rails-fpr-kits/
https://www.hyundaiaftermarket.org/forum/index.php?/topic/59038-fpr-kits-and-fuel-rails/
Thanks for the great information guys. I didnt know the stock rail was that good. I'll definitely tap it and use the fittings Im getting. Appreciate the advice and + rep to you all.
they sell the tap at ACE for about 20$ or so i think. Also sell the drill bit for it, but it likes to lock up at the injector opening. I use a carbide dremel bit to open it up for the tap and make sure its very smooth and cleaned up before I install the fitting.
Yea, I got about 3 people interested in a GB. Not worth it.
It's easier to buy a 3/8" tap at a plumbing store for $8, and have it powder coated locally for $30.
