Best way to drill into oil pan
Old Feb 6, 2012 | 01:35 PM
Cereal Killer's Avatar
Vehicle: 2005 V6 Tib
Default Best way to drill into oil pan
What is the best way to drill a hole for a return oil line into the oil pan? I would rather do it with the pan still attached if possible.
I have read about dipping the drill bit in oil and drilling the hole slowly to catch all the shavings.
Anybody have any experience doing this to their drill bits?
Old Feb 6, 2012 | 01:40 PM
Red Raspberry's Avatar
Steel pan? If so drill and then use a magnet to drag the pieces to the drain hole. Drill slow and don't push a lot. Also if you can have a blow gun on the bit as you drill so shavings don't stick to the bit.
Old Feb 6, 2012 | 03:22 PM
01steve's Avatar
Vehicle: 2000 hyundai tiburon
i'd take the pan down on your next oil change-... it just doesn't seem like it'd be worth the risk.
Old Feb 6, 2012 | 10:20 PM
^ This.
You can even catch the oil and reuse it if you're between oil changes. For $40 worth of oil you're better off losing a full crankcase worth than sending iron shavings into a main bearing or w/e. Drop the pan, drill/tap, replace the pan.
Better still, drop the pan, drill/tap the BLOCK.
Old Feb 6, 2012 | 10:33 PM
300D50's Avatar
Hmmm... Where on the blck would you drill a return hole?
One would think it best to do it on the pan, to avoid adding stress risers...
Old Feb 6, 2012 | 11:05 PM
Stress risers on the bottom of the skirt that's basically only holding up the oil pan? Not something I'd worry about too much. Low on the block.
Old Feb 7, 2012 | 06:28 AM
How about into the valve cover?
Old Feb 7, 2012 | 08:32 AM
03tibe85's Avatar
Vehicle: 2003/Hyundai/Tiburon
The OP's profile says he has a V6 Tib. It has essentially a 2 piece pan. The top part has the integrated cradle for the main caps, and the bottom small steel portion continually sits below the fill line. Both are not ideal for drain locations but if I had to choose I'd weld a fitting on the steel portion close to the filler pickup tube so that it helps empty the turbo drain line.
Old Feb 7, 2012 | 10:33 PM
^missed that. Dang new technology tripping up crusty old veteran members . . . I seem to have this habit of thinking hyundai = L4 engines. Good catch. But draining the return oil to below the oil level in the pan seems . . . not great to me.
