Cams
Old Mar 14, 2006 | 07:44 PM
well since im gonna get my head p&p ive been thinkin about cams
any recommendations?
again im goin with s/c so would it be different than turbo cams?
i was thinkin somethin like 255 duration i dont care about gas mileage i just wanna be able to tune it with my smt...
again these have to work when i turn off the s/c and run completely NA...
Old Mar 14, 2006 | 07:47 PM
kb5133's Avatar
Um...how do you "turn off" the s/c?
Sorry I don't know enough about cams to give you an answer.
Old Mar 14, 2006 | 07:48 PM
hehe long story on how i "turn it off" ill explain when the project is done...somepeople probably know though
Old Mar 14, 2006 | 07:51 PM
kb5133's Avatar
I've never seen a 255 cam for our cars??
Old Mar 14, 2006 | 07:53 PM
regrinds....i8acobra has em
Old Mar 14, 2006 | 07:54 PM
yamaha's Avatar
Vehicle: 2000 Hyundai Elantra
How much are the regrinds going to run you faith?
Old Mar 14, 2006 | 07:59 PM
donno yet i wanna have specs first then ill shop around...
Old Mar 14, 2006 | 08:09 PM
kb5133's Avatar
Sounds like unchartered territory. I haven't seen many s/c setups with modified cams. Regrind...is that down from a 264 or is there a shorter one?
Old Mar 14, 2006 | 08:32 PM
albert's Avatar
It is very easy to turn a supercharger off. Many OEM superchargers have this feature.
You put a clutched pulley (electromagnetic) on the S/C that way when you WANT the supercharger it's there, and when you don't, you won't have the parasitic drag.
AC condensors have clutched pullies on them, so they are NOT a "new" thang.
I would Hit up RPW. David will reccomend something for ya, even if he has to make it special.
BTW...yes, SC cams are different from Turbo Cams. SC's can tolerate more valve overlap due to the lack of exhaust backpressure. Due to the HIGH backpressure inherent in turbocharged setups, they require very little/no valve overlap.
Old Mar 15, 2006 | 08:46 AM
IJSTBRNDU's Avatar
depending on how much boost you're running i'd probably go with 268/264 or 264/262 with a 10.2-10.5mm lift, but thats just my opinion...it should give you a better low-mide range curve than 272's that everyone always says to go with. the power will be smother rather than a late kick associated with 272's
dont get me wrong 272's are great but if your redline is low, 7k and below, your useable power curve is just too late/ to much of a blip compared to the rev range of the engine/ useable range associated with the combinations i listed above.
