First Run With Hyundai Tiburon 1.6 Turbo
Vehicle: Hyundai tiburon 1.6 TURBO
hi....after few months.....yesterday i can run for first time with my Coupe 1.6 Turbo.....without DOWNPIPE
I need to regulate the blow because the turbo charges at 4000rpm and the blow open to 4500 so all the pressure go out
i´m going to buy a WIDEBAND O2 Sensor to regulate my APEXI safc2 more or less
here is a the video.
http://www.fastuning.com/video.php?id=101
Vehicle: Elantra HD / 2007
Awesome!
Do you have any numbers?
Why did you take of head? Did you installed decompression plate?
Tell about specs, what did you do for fuel management, what turbo is that... etc.
i dont have numbers....cause yesterday a run first time.
the turbo IS THE SAME that you had to buy....but you have problem with the seller.
the electronic now i´m with apexi safc and the FUEL PRESSURE about 45 PSI
looks like you had the same porblem as another member with that kspec manifold. That block of steel doesn't look the best but it gets the job done and brings the turbo out far enough so it don't hit the block..
the manifold is the OBX no KSPEC manifold.....but yes....the problem is that the turbo hit in the block...exactly the wastegate is what hit...
i need another manifold....where can i BUY this manifold??is custom made?
Pic of log-style manifold installed
MOD EDIT: pic is too big, replaced with a link.
