Smt6 With Secondary Fuel Rail
Old Nov 8, 2006 | 09:00 PM
nate704's Avatar
I'm going to use SMT6 with secondary fuel rail.
Do you guys think SMT6 will work with the secondary fuel rail well?
I'm going to run 440cc injectors with the fuel rail.
Thanks
Nate
Old Nov 8, 2006 | 09:04 PM
Alex01tib's Avatar
Yes it will, very well, i have it installed right now; super easy to tune.
440's are perfect, thatll give you about 700cc per cylinder max.
Old Nov 8, 2006 | 11:08 PM
yes, itll work great.. im sure it works about the same as the Emanage which is what i am running in my car with a dual fuel rail, and i am running my 340cc in batch mode yO.. so they are pulsing 2X per inj. pulse, so they are running as 680cc injectors on top of the stockers running like 245cc.
Old Nov 9, 2006 | 04:24 AM
melandri_nl's Avatar
Smt6 is that the stock intake manifold with 4 extra holes for 4 extra injectors ? Is that not hard to install ? or can you just link the injectors ?
Old Nov 9, 2006 | 08:25 PM
Denisst99's Avatar
the smt-6 is a piggy back (aka fuel controler)
you will need 2 weld extra injectors bungs to your stock intake manifold and build a new fuel rail
or use a spacer that goes between the cylinder head and intak manifold that is built to accpet the 4 extra injectors
