Thinkin Of Boosting The Tib.
Well after I'm dont with the body work I was thinkin of makin it into a sleeper. My question is could I boost it at 7-8 psi with stock internals, I really dont know how stong the internals are on the tib. How much HP could I expect to get out of it? Thanks
yes 7-8 would be fine with stock internals, you can take it up to 13-14 lbs and still have complete peace of mind, and some have taken it up to 16-17 on stock internals and stock compression but thats pushing it.
and at 7-8 pounds with decent tuning and some good complementing mods youd be looking at 200-220whp depending on altitude, temperature, supporting mods, compression, and luck, lol
From: York. About 2hrs from Philly and 4 hours from Pittsburgh
I'm puttin one in on wednesday with stock internals at 8 psi until I find time to throw some pistons in there. If something terrible happens, I'll warn you but nothing should go wrong (fingers crossed) haha
7-8 psi should be fine with stock internals; its when you get over 10psi that you have to start doing the big stuff. Putting in low comp pistons (for example) now at such a low psi would make you lose some whp.
yah you have to be able to fine tune the afr to dare breaking double digit boost, safc/fmu wont cut it
you need smt/uni/emanage/standalone/etc
Thanks alot for your help, I Will probably start putting my "Grocery List" together after christmas once I get the tib painted. Really just looking to beart civics lol.. Thanks guys.
you will need the following
new rod/main bearings
1.8L rods and pistions "if you want to go up to 400whp"
oil pump "XD VVT" has a higer psi so you can run "oil cooler, turbo" its the standard over here on any build if you want more oil psi open the pressure release bolt and put a 10mm bolt in there.. we have done it
gasket set top and bottom end
change out the timeing belt and waterpump while you doing it..
new "oem" intake/exhaust valves with valve seals
check all clearances on the mains/rods/pistions
boost away
turbo parts
FPG
255 in-tank
550cc inj or what everyou want to run..
wastegate/BOV/Fmic
3'down and exhaust pipe
cams street 268 high power and top end 272
since you are running airflow you will need to get a standalone
boost away
turbo parts
FPG
255 in-tank
wastegate/BOV/Fmic
