Rebuilding Engine
Old Sep 21, 2006 | 10:40 AM
Mickel's Avatar
well this idea came because a spark plug in the 3rd cilinder broke and the little piece went inside, today i just took out the engine and tranny.
now what i wanna to the engine is a:
head
3 way valve angle job
port and polish
to the block i want to know which set of wiseco forged low comprecion pistons, and where to get em also. Should i get
82 or 82.5 bore which one is better?
if i change the pistons, should i change the rods as well? or stock rods can handle 250-300 hp?
i am going to change the main and rod bearings also (stocks).
btw i am turbocharged.
any other sugestions?
my goal is 300 hp.
Old Sep 21, 2006 | 10:56 AM
your car comes from the factory with a 3 angle...
and wiseco doesnt make a 82mm piston only 82.5 and 83mm
Old Sep 21, 2006 | 11:42 AM
JonGTR's Avatar
I had the same thing happen when I was spraying nitrous. the only thing that was wrong was a broken exhaust valve where the piece had to escape. $16 fix for a valve.
Old Sep 22, 2006 | 05:14 PM
renante's Avatar
brand new stock rods are probably rated above 300hp.
but not stock rods that are 7+ years old.
for my car pushing above 300+hp, resulted in damaged bent rods.
consider investing on forged pistons, forged rods, metal gasket.
Old Sep 22, 2006 | 05:16 PM
thats cuz your tuners were morons^^
stock rods WITH arp bolts will hold just fine
when the rods snap its usually cuz of the stock bolts
Old Sep 22, 2006 | 11:53 PM
renante's Avatar
faithofdragon?
my suggestion is strengthening the engine.
Your suggestion is keep persisting with OEM and standard parts.
and keep pushing it over 300hp until something breaks?
Our cars are not Nissan rb30 engines that can push 400hp on OEM form.
Cooper gasket cracked at 20psi, 330hp, arp head bolts, modified head etc.
Because if I knew beforehand that cooper and oem gaskets are rated at only 10-16psi Maximum.
I wouldn't have pushed the engine that much.
Old Sep 23, 2006 | 11:14 AM
Jay-M's Avatar
Vehicle: 01 Tiburon
QUOTE (ZekroN @ Sep 21 2006, 11:40 AM)
wiseco can make you a 82.0 mm bore if you want to... just give them a call but if your goal is 300 hp then, get the 83.0 mm bore
pm jongtr... maybe he can hook you up somehow
the rods, might as well... your engine is already torn apart... why not just do it and have a piece of mind
Old Sep 26, 2006 | 07:52 AM
Mickel's Avatar
what do u guys think about shotpeen the rods + recondition them?
$120 all 4
Old Sep 26, 2006 | 08:58 AM
yamaha's Avatar
Vehicle: 2000 Hyundai Elantra
Alittle on the expensive side, shotpeening shouldnt cost more then 75USD for all rods, and polishing should be a bit more.
Old Sep 26, 2006 | 09:42 AM
Mickel's Avatar
he charged me 10 bucks each rod for shotpeen, the rest its for recondition.
