Maybe a new thread for cold side
Vehicle: 2003 Turbo Tib
Centrifugal Compressors (Turbo and Vortech/Paxton style Belt driven units) take a big hit in power when the inlet side is screwed up by several things:
1. Compressor Wheel does not fill blade slots evenly
2. Too much pressure drop on the inlet side (like trying to run a mile with your nose plugged up
3. Inlet plumbing too long
4. Restrictive air filter
5. Sharp bends right before the inlet (see #1)
6. Discharge from Compressor has a tight 90 degree bend for package purposes and causes turbulence
7. Air flow from compressor causes uneven air distribution to the Carburetor
8. Inter-cooler has too much pressure drop
9. By-pass valve plumbed in the wrong spot on discharge pipe
1o. Take it from here Gentlemen.............................
