Help With Aem Fic Fuel Management
Old Apr 27, 2010 | 06:25 PM
99sharkbmr's Avatar
Vehicle: 1999 hyundai tiburon turbo/ 2001 Tiburon(sold)
Need help, hooked up needed wires based on info recieved on other sites and also the ecm electrical schematic from hyundai dealership. For now just intalling fic to get to know better. in near future we are installing a turbo which is when this will be used harder.Car will crank but not turn over. I assume until I want to make changes to fuel input, etc that the ECM will handle this. any suggestions would be appreciated
PS-also installed aem uego wideband o2 sensor at the same time.
Old Apr 27, 2010 | 06:57 PM
Lazyshot's Avatar
Same issue as above. I soldered up a PnP harness for the FIC, but when I went to start it, it wouldn't turn over.
I had an LC-1 installed at the time.
Right now the car is running fine without the FIC.
Old Apr 27, 2010 | 07:28 PM
radu_rd2's Avatar
Vehicle: 2006 Pontiac GTO
https://www.hyundaiaftermarket.org/forum/in...showtopic=16460
https://www.hyundaiaftermarket.org/forum/in...showtopic=16501
Old Apr 28, 2010 | 08:10 PM
99sharkbmr's Avatar
QUOTE (radu_rd2 @ Apr 27 2010, 09:28 PM)
Old Apr 28, 2010 | 09:00 PM
BlueRD2's Avatar
Make sure there is not maps already on the FIC.
It should run like normal if you have the test harness on it or there is not maps on the FIC.
If not check your wireing.
