Ok..need a low-psi parts list!!!
Old Jan 14, 2003 | 08:52 AM
MyLilTibby2001's Avatar
Default Ok..need a low-psi parts list!!!
Ok heres my deal...I drive a 2001 Tiburon, wanna go for a very simple and low-boost custom turbo setup, and have a a thousand bucks to spend for now just to get things started...Im JUST looking to get something going in my car that can be upgraded as I wish and I dont wanna intercool right away. I already have a t3/t4 hybrid turbo but nothing else. Would you guys be able to help me out with some sort of "parts list" to assist me in setting up a basic system?..I was thinking about the CNK manifold, but is there something cheaper/easier. Also about the compression ratio..should this be lowered even on a low-boost setup, or is there an actual psi rating beyond which the stock internals cannot hold up? And I know an ECU is pretty much mandatory for high-performance setups, but I just want something that works..not something that gives me tons of power..and LASTLY,.. at what psi rating is it neccesary to replace piston rings/rods..Im really excited about getting something going soon, and ALL help is greatly appreciated.. thanks!
Old Jan 14, 2003 | 09:41 AM
skierd's Avatar
Vehicle: 1997 accent L
If you take a minute to search, you'll find more than enough info. One thing I would do right away is drop that turbo for something smaller if you want low boost.
Old Jan 14, 2003 | 09:43 AM
Just searched pal ...no parts list for a low-non-intercooled setup on here or any other forum. Can anyone else help me? thanks.
Old Jan 14, 2003 | 10:22 AM
Lobert's Avatar
Darn old arsche Laptop.
[ January 14, 2003, 05:24 PM: Message edited by: Lobert ]
Old Jan 14, 2003 | 10:23 AM
Lobert's Avatar
Dude the parts list is basically the same as every other parts list for a turbo setup. It doesn't matter. The first part that I would suggest is the book "Maximum Boost" by Corky Bell. That book will tell you just about everything that you need to know, and then some.
Just my $.02
Old Jan 15, 2003 | 07:20 AM
Have it AND read it...but it doesnt cover HYUNDAI TIBURON specific turbo specs..!!! lol
Old Jan 15, 2003 | 12:21 PM
skierd's Avatar
Ok, i searched for you since you obviously arent very inclined to do things for yourself.
http://www.hyundaiaftermarket.com/noncgi/u...c;f=39;t=000090
http://www.hyundaiaftermarket.com/noncgi/u...c;f=39;t=000076
http://www.hyundaiaftermarket.com/noncgi/u...c;f=39;t=000001
http://www.hyundaiaftermarket.com/noncgi/u...c;f=39;t=000033
Really good ones:
http://www.hyundaiaftermarket.com/noncgi/u...c;f=39;t=000059
http://www.hyundaiaftermarket.com/cgi-bin/...c;f=39;t=000047
This one even has a complete parts list:
http://www.hyundaiaftermarket.com/cgi-bin/...c;f=39;t=000030
http://www.hyundaiaftermarket.com/noncgi/u...c;f=39;t=000014
Sorry if i'm coming off as an *** , cause I am, but searching isnt that hard to do. There is nothing special that the tibby needs compared to other cars to turbocharge it.
Old Jan 15, 2003 | 12:56 PM
Haha thanks Skierd...no need to throw a fit over a simple post though. But thanks anyway... wink
Old Jan 18, 2003 | 01:50 AM
turbulence's Avatar
dude, you didn't search. one of the posts with the complete parts list was started by you. wtf need someone to come hold your hand while you install the turbo? wink if you read the book and walked away knowing anything from it, you wouldn't have said that because it didn't specifically mention hyundai tiburons, it didn't help you. read it again. s**t, i'm only through the first two chapters, and already i've learned more than i've ever read on the boards. or at least the information is in a more concise format.
::edit::
also, if you've read ANYTHING on the boards about turbocharging the BETA engine on stock compression, you'll know that you definiately need an intercooler. and maximum boost would have left you with the same knowledge, if you READ it, not skimmed over it. well, you don't need an intercooler...if you want serious detonation problems.
[ January 18, 2003, 03:31 PM: Message edited by: turbulence ]
Old Jan 18, 2003 | 12:55 PM
NUTTANICK PREMBOON's Avatar
I had done low boots turbo with my beta too wiyh IHI RHB52 at 5psi and stock gasket ,with rising Webber fuel regulater ,Welbro fuel pump ,additional injector control HKS AIC nuttanick@yahoo.com
