Fuel Pump
Old May 5, 2003 | 01:28 AM
Demonio's Avatar
Vehicle: 2004 Accent
Default Fuel Pump
What kind or espec. have the tiburon 97 fuel pump?
Old May 5, 2003 | 02:12 AM
What is the question?
Yes, the 97 Tiburon has a fuel pump. The brand is Bosch, but I'm not 100% sure on the model number.
[ May 05, 2003, 09:13 AM: Message edited by: Random ]
Old May 6, 2003 | 09:47 PM
Demonio's Avatar
I need to know the amount of pressure with which it works (lbs), since I must buy an additional fuel pump at least with an increase of 50% since I am poor of fuel by the installation of the turbocompressor.
Old May 7, 2003 | 02:07 AM
Shadohh's Avatar
I believe the stock pump makes 70 lph @ 43 psi
and a 1g Talon/Eclipse GST pump is 102lph. @ 43psi
and 2g GSX is 140 LPH @ 43psi
Walbro "255" LPH runs 230lph @ 43psi
These are all at the rated 12.5 volts.
You can usualy squeeze another 30lph running them at 14 volts.
