Cams
Old Jan 27, 2003 | 04:31 AM
Jon's Avatar
Jon
Default Cams
It just reminded me after seeing the new cams in SR has anyone seen anything about cams for a turbo setup yet.
Old Jan 27, 2003 | 05:40 AM
Shadohh's Avatar
I been looking myself.
Thou I have not gotten into reading on the subject about what makes a "GOOD" turbo cam.
I just know the basics.
Less valve overlap and a higher lift exhaust cam.
I think those SR cams are relabeled HVE cams.
Old Jan 28, 2003 | 07:29 AM
turbulence's Avatar
what about rpw's cams? they're aggressive, but i don't know if they're for the quadtb, n/a route.
Old Jan 28, 2003 | 07:49 AM
Jon's Avatar
Jon
I think as far as i know the duration is to long so there will be a lot of valeve overlap so the tubo will end up blowing straight through. I think this is correct unless they have released turbo ones i havnt seen?
Old Jan 28, 2003 | 08:30 AM
99mini's Avatar
i got some cat cams recently for an NA setup. the instal shop said they would be ok for turbo if i got some cam gears and retarded the intake cam a bit to reduce the overlap.
Old Jan 28, 2003 | 11:02 AM
turbulence's Avatar
i don't know about the alpha engines, but betas don't have "cam gears" that we can just replace and adjust the timing. i would check on that.
Old Feb 12, 2003 | 04:18 AM
Frostbyte's Avatar
turbulence:
advancing the exhaust would advance the intake.
[ February 12, 2003, 11:21 AM: Message edited by: Frostbyte ]
Old Feb 12, 2003 | 08:59 AM
turbulence's Avatar
well, no s*it, frostbyte. poke but what if you don't want to adjust intake and exhaust valve timing together? that's what i meant.
Old Feb 13, 2003 | 02:49 AM
Frostbyte's Avatar
turbulence:
That is a picture from webtech of the alpha engine which I think shows the cam timing cannot be adjusted seperately by changing the cam gear. If one cam (exhaust) is advanced, so would the other. 99Mini's install shop told him/her the cams would be ok for turbo if he/she retards the intake to reduce the overlap. With the alpha, and beta, retarding the intake is done by retarding the exhaust, and overlap will remain constant.
unless of course you want to do the work outlined in This post .
Old Feb 13, 2003 | 06:59 PM
lantraluvr's Avatar
Vehicle: 1999 Elantra
I think they make/sell turbo cams in Korea.
