Fuel Injector Question
Old Dec 9, 2002 | 02:02 AM
David Dickson's Avatar
Default Fuel Injector Question
Hey,
Anyone know if there is any other compatible fuel injectors from other vehicle mfrs that work with the Beta I/II engines? I'm trying to find out if there are any higher flow rate OEM injectors from other mfrs that will drop in to my tibby.
Yeah I know I'm cheap but if it'll work...why not save a few bucks in the process...
Old Dec 9, 2002 | 02:09 AM
Hyundai4g63T's Avatar
Vehicle: Had 96 Elantra Wagon
450cc injectors from a Turboed Mitsubishi Eclipse should work.
Old Dec 9, 2002 | 02:15 AM
Would that be the 2G Eclipses? Thanks for the input..
Old Dec 9, 2002 | 02:18 AM
Either 1g or 2g but he 450's were only in the Manual Tranny Eclipses the Auto's run 380's.
Old Dec 9, 2002 | 02:37 AM
Thanks a lot Hyundai4g63T. Now its time to start my xmass list ;-).
Old Dec 9, 2002 | 03:11 PM
Just a warning...
BETA 1 & 2
The Mitsu injectors fit the fuel rail, but not the intake manifold. You would have to bore out the IM to fit the Mitsu injectors.
[ December 09, 2002, 10:21 PM: Message edited by: Random ]
Old Dec 13, 2002 | 11:27 PM
VALKYRIE YB70's Avatar
Any ideas re. an injector upgrade for a `95 Scoupe Turbo (direct replacement)?.
Thanks!.
Old Dec 14, 2002 | 01:34 AM
Thanks Random, I forgot to metion the mods need to the intake.
[ December 14, 2002, 08:45 AM: Message edited by: Hyundai4g63T ]
Old Jan 2, 2003 | 04:00 PM
CRO_OOL's Avatar
i tested the impedance on the 4g63t(vr4, eclipse1g etc) injectors and they ready sumwhere along the lines of 2ohms which means there is no way of running it with beta motors unless you where going to change engine management systes or used resistor packs in series with the power connections.
Old Jan 2, 2003 | 04:11 PM
4G61's Avatar
You can easy to find on FORDRacing.
http://www.fordracing.com/parts/search/
use keyword "injector"
on 2,3 page, U can find four high flow injector. (19 lbs/hr 24 lbs/hr 30 lbs/hr 42 lbs/hr)
24 lbs/hr type can use on your car.
may be no need to match EMS data.
If you get, let me know it's price.
Ultra power 4G61
[ January 02, 2003, 11:18 PM: Message edited by: 4G61 ]
