Wiring E-manage Ultimate To Ecu
Vehicle: 97 tiburon
Anyone have any info on e-manage Ultimate Wiring to the ECU, I have already used Search. I'm going to wire it up this weekend, any info would be great!
thanks
thanks
quick question.. why did you go with the emanage ultimate and not emanage blue? planning on 500whp?
im not sure how to wire it up, i have the emanage blue.. should be straight forward though..
Vehicle: 97 tiburon
As you know the emanage ultimate has move options, that's why I when with it. I have a secound engine which I'm building so I figured the emanage ultimate would be a better setup for me. the wiring does look pretty straight forward but I thought I would see if anyone else had any wiring diys made up that would make my life a little easyer.
i dont think there are any specific DIYs for the emanage, but there is an ECU pin-out and the emanage tells you what wires are for what..
are you going to be running a dual fuel rail setup, or trying to by pass the MAF?
Vehicle: 97 tiburon
I've been looking around this site, it's pretty good http://www.emanageforums.com/forums/index.php?
http://www.mohdparts.com/emanage/ultimate/...nual/index.html
Vehicle: 97 tiburon
got it all wired, wasn't that bad! also got the turbo timer in.
http://s176.photobucket.com/albums/w183/s1...nt=DSC00069.jpg
