Turbo Prep
Old Oct 4, 2007 | 01:02 PM
gitrplayr2024's Avatar
any1 kno off the top of their heads what specific engine internals would need changed out in order to run about 20 lbs of boost stably?
Old Oct 4, 2007 | 01:04 PM
Kantizuni's Avatar
Vehicle: 2000 Turbulence
Try looking around.
http://www.rdtiburon.com/index.php?showtopic=18676
^^ That's on the same page where you clicked New Post to make this thread.
Old Oct 4, 2007 | 09:15 PM
yes i kno this.. and ive already read that. it seems a bit overkill tho. if i did all that id prolly end up paying more than i did for the whole car. i just want to kno the necessary components that will need replaced.
*removed quote. Please don't quote the person above you.*
Old Oct 4, 2007 | 09:23 PM
Role Reversal's Avatar
Vehicle: 05 Subaru WRX
Something to lower your compression, but if you don't know that you may want to do a bit of research before boosting your car. Also if you are looking to run 20 lbs of boost you will probably wind up paying more than your car is worth in parts. Thats just the nature of boosting a hyundai.
Old Oct 4, 2007 | 10:29 PM
20 lbs set up is going to be around 3k if you do it cheap and allready have a good clutch set up.
Old Oct 4, 2007 | 11:41 PM
1. Search before you post.
2. Do NOT use that LEET or INTERNET talk in here, I'll just close your threads if I see that "ne 1 no wer i kan get 2rbo?" Take the time and type out the extra few letters, or almost no one will read your posts.
3. Don't quote the post above yours. Use the ADD REPLY button at the bottom of the page.
What's on that list may be more than you want to spend, but you can either cheap out a turbo and keep fixing it for years, or you can do it right the first time.
Old Oct 4, 2007 | 11:52 PM
LOL this should sum it up
Cheap Fast Reliable
you can only have two... you pick
Old Oct 5, 2007 | 06:01 AM
JonGTR's Avatar
1 step at a time.
Focus on building your turbo kit first. Once you have it built and feel that it's reliable, then you can begin working on the motor.
I'm running a completely stock motor right now and putting down at least 270whp. You may find that you're happy with that. But like I said, it takes quite a bit of work to get even that far.
Old Oct 5, 2007 | 08:01 AM
okay.. i came to this board because i am not as experienced as some of you veterans. i came with intentions to acquire information from people who share the same passion but if you guys are just gonna flame me for not being as knowledgeable as yourselves or the way i type, than i guess i will have to find a new board.
Old Oct 5, 2007 | 08:12 AM
Kantizuni's Avatar
You just don't get it.
You need to understand how a turbo works before you go and build one. You can't be spoonfed, you need to have that knowledge first or else you're going to blow your engine. You -need- to read more about it and be able to answer these questions on your own before you even consider buying that first part.
