Cutting Stock Exhaust Manifold And Welding Turbo Flange?
Has anyone seen or tried to cut the stock exhaust manifold and weld a turbo flange on it ? I was thinking about doing this and welding a 14b turbo flange on it for my project , and was looking for some insight or a picture into this method. THanks
NATE
NATE
how did that work out for you? My stepdad works at a welding shop so im sure he has tools to do it. DO you have any pictures of the job. THanks for the insite.
I had one that i had bought off java who had bought it from somebody else.
I was going to use it until i decided to get a kit, not a bad idea tho, esspecially for the california peeps.
Vehicle: Had 96 Elantra Wagon
The key is to heat the manifold before tig welding (GTAW), and to use a high nickel filler rod.
If you don't heat the cast piece first it will crack.
Well a Turbo system is defiantly something you don't want to nickel and dime. I have been there and done it all and you don't want to skimp on a turbo setup.
Sorry meant to say i sold it, havent seen the guy post that he used it so he may have it, lemme see if i can find who i sold it to.
Not really nickle and diming it. Just figured that using the stock exhaust and moddin it would be just as good as obx( without the looks ). Just lookin into all my options.
How much would I be able to get a custom manifold built for a 14b ?
