Pistons..what Shall I Do?
Old Sep 13, 2008 | 12:47 PM
balbains324's Avatar
Vehicle: 1998 Hyundai Coupe
Hi guys
I have CP pistons installed at the moment 8.8:1 compression.
Piston 3 has gone tits up and I need a new one, I don't think they do singles.
This has broken because faulty valve must have hit it.
I was thinking about putting stock pistons back in 10:1 compression.
I have seen 1.8l Tiburon pistons at Kspec for $159...best value but compression will be 11.0:1
Is it wise for me to go with 11:1 compression and maybe reduce the boost from the supercharger or shoul I go with stock pistons that I can't get from anywhere or do I shed out for another set of CP Pistons?
11.0:1 means more power - high risk
Stock = conservative
8.8:1 = Less power but very safe
Need expert advice on this..please help
Old Sep 13, 2008 | 02:14 PM
im pretty sure you already made a very similar thread and there was a ton of good responses and a few from me.. check out your old thread..
here it is.. other piston/compression thread
i would use stock compression pistons, just the stock 2.0L pistons..
i dont believe your pushing over 12psi, so you will still be safe..
getting 1.8L pistons on a FI motor would be dumb.
Old Sep 15, 2008 | 08:02 AM
David Dickson's Avatar
CP will sell you a single piston provided they have some already machined. smile.gif
