What Is Needed To Run Low Impedance Injectors
Old May 7, 2008 | 05:25 PM
OK I want to get this in one place and nice and detailed for searches and everything.
Now, Ive heard people say and read that to use the Low Impedance in a car that uses High Impedance stock (like ours) you need a resistor box. Now my question is: Is this as simple as wiring in a resistor unit found on ebay by finding the diagrams and splicing. Can you put an actual resistor inline with the wire? Basically what is the cleanest, easiest way to get this done?
Ebay Resistor box
For anyone wondering, Low Impedance injectors are much cheaper to get for the higher outputs. But our stock computers cannot drive them correctly.
Thanks in advance guys.
Old May 7, 2008 | 09:38 PM
Denisst99's Avatar
you can use aluminium cased resistors
or use a honda or DSM resitor box
it works,but oftne you can get high imp injectors for the same price then low
and they fit with our fuel rail configuration
Old May 8, 2008 | 06:28 AM
JonGTR's Avatar
Have you done a google search on resistor installs? There's several DIY's out there.
Go buy 4 10ohm resistors from Radio Shack.
http://www.homemadeturbo.com/tech_projects...tors/index.html
Old May 8, 2008 | 07:34 AM
Mad_john's Avatar
I ran into the same problem as well, Hyundai makes has a car that runs a resistor pack but it was not exported to the US its the very first XG. 1989.. they used a 2.4L engine.. they also used the same engine in the sonata that they exported to the US.. i will post the part # tomorrow. your best bet is to look at the old school sonata 89~92 2.4L model..
Old May 8, 2008 | 11:19 AM
Adding the resistor inline seems like the best option. And I didnt find high impedance injectors that went to high without being a lot more. The only ones that are affordable it seems are the Ford ones and Im looking for something a bit bigger. Im going to see if I can get the 550s I got for cheap to work otherwise Ill sell them and buy some others.
Old May 8, 2008 | 02:30 PM
tdonnell's Avatar
Can't you run low impedence injectors with the prs4?
Old May 20, 2008 | 06:07 PM
That thing is long gone. And with the MS you need to go through all kinds of stuff to use them. So Ill just wire in the resistors and be good to go.
