Air Ram Throttle Body
hi i was wondering if the stock throttle body from a 2005 gk beta 2 will fit on the air ram..remmeber the icv is different from beta 1.....can someone help me if it doesnt what should i get and it has a tps sensor on the body
What you need, since you are swapping over to the Beta 1 IAC and MAP, is the Beta 1 BBTB.
So you will be running a Beta 2 Airram, Beta 1 BBTB, Beta 1 Idle Bypass (IAC, this will take the place of your IAC on TB/IM on the Beta 2), and a MAF to MAP swap.
Again, contact ABQELANTRA, as he has done this in the past, all except for the MAP conversion, he can help you out. I've said this like a dozen times.
