Coolant Feed/drain Line Location
Old May 31, 2008 | 08:26 PM
bassboy3313's Avatar
Vehicle: 1997 Hyundai Tiburon FX
hey. where could i connect the coolant feed and drain lines for my t3 turbo on a beta (rd1) engine?
Old May 31, 2008 | 09:14 PM
sleepertib's Avatar
TB coolant lines bro. Just do the TB bypass mod if you havent already.
Old May 31, 2008 | 09:16 PM
dddude55's Avatar
Vehicle: 2011 Kawasaki ZX6R
You connect them where the Throttle Body(TB) coolant lines are. If you have done the TB bypass then you already know where to get it from. If not then go look at your TB.
Underneath it there are 2 nipples with hoses attached. One is an intake hose and the other is the exit point. Take those hoses off your TB and Engine and run the lines from the engine to your Turbo.
DO NOT START THE CAR UNTIL YOU EITHER LOOP A HOSE INTO A U ON THE ENGINES NIPPLES OR YOU HAVE THE LINE ON YOUR TIB
TB Bypass Mod
Old Jun 1, 2008 | 12:00 AM
thanks to eveyone. that was the most simple thing i have ever heard. boy do i feel dumb. sad.gif
Old Jun 1, 2008 | 12:10 AM
dddude55's Avatar
Hope it all works out for you.
