Need Turbo Advice!!
I'll tell you exactly what I want to accomplish. Any/All feeback negative or positive is welcome. Teach me!
I have a completely stock Tiburon right now, but by May of 05 I want to be boosting smile.gif
What I'd really like to achieve is 300+ HP, or to say, if I raced an STi or Evo8 off the line, I'd be able to wave goodbye to it. Is this even possible with our car?
What kind of Turbo kit should I be looking at to achieve this. Also, if the kit I need won't work with the stock internals, what can I do in the mean time before next May that will get me ready for a Turbo Kit that can boost me 300+
I understand LSD and performance clutch are necessary. What else will need to be done? Expensive? Difficulty?
truffully your looking at a least$1300 for stand alone unit $2900 for the turbo kit $1000 for lsd $800 for clutch and something to lower your compression of car eigther pistons for $300 or kspec gots a gasket to lower it for $300 and expences to be put in everything so your over $5000 now good luck
[quote="Dweet"]I could do 300whp under $4k ... I think I'm going to hit 250whp at $992 smile.gif[/quote
good luck with that dweet....
you are saying that you will be pushing 250whp with stock pistons and stock clutch? unless you included those in your $992 :roll:
