92-95 Elantra 4G63 Swap:90 E-Prom AWD ECU in my Elantra Swap
Old Aug 10, 2004 | 04:26 PM
Dweet's Avatar
Default Re: Window Tinting..
I found a guy with a 90 E-Prom ECU for AWD , a wiring harness and a 1G MAS. First question, will the AWD ECU work with my FWD setup or is there a way I can get it to work? Also I used all the sensors except the O2 from the engine i bought which is a 90. Will this work? If so Im running a wiring harness this weekend.
Old Aug 10, 2004 | 09:41 PM
Dweet's Avatar
Default Re: Interior Paint Ideas
sounds good... look its lits project ECU/wire harness swap this weekend
Old Aug 11, 2004 | 03:59 PM
Dweet's Avatar
Default Re: Oil type?
Yeah, im going to take pics and everything and probably wire up my turbo timer since the harness will be outside of the car and wiring could be done with little to no effort.. better than laying on your back on the driver side counting pins with a flashlight in my mouth, a klein in one hand and connectors in the other
Old Aug 12, 2004 | 08:57 AM
Dweet's Avatar
Default Re: need help with tires
just got a PM back from him and the harness is basically no good. So I know I can still use the hyundai harness but I need to run the wires for at least the knock sensor. what other wires do I need to run or other modifications do i need to do
I cant find an ECU pinout on webtech either, there is a longlist of what the pins do but then I'd have to read each diagnosis procedure and write down which pin does what wink1.gif
Old Aug 12, 2004 | 07:50 PM
Dweet's Avatar
Default Re: S-AFC2 TUNING
uhmm barometric wirespin? please explain... also do you know where i can get a pinout of the hyundai ECU.. oh and i dont have to switch any pins on the harness?
Old Aug 12, 2004 | 09:34 PM
Dweet's Avatar
Default Re: Tail lights
after re-reading what you posted it seems that there are two wires missing in the MAS harness for pins 7 and 8.. So I have to run 4 wires total. 2 for the knock and pins 7 & 8 on the harness.. which two pins are 7 and 8?
also does polarity matter with the coolant temp sensor?
