92-95 Elantra 4G63 Swap:1G DSM PS pump on the Elantra
Re: A little more progress *MORE PICS ADDED*
The fittings arent quite right and since you're the only person that has worked with hyundai's and DSM's that I can get ahold of relatively quick what is the best way you think I can get the PS pump to work? BEcause somehow my PS pump from the elantra isnt around.
Re: Alpine coupe
did you have any plugs that didnt get plugged in to the engine.. i have a few... if you could quickly list the ones i need to have done and maybe where they are located if you know them off hand that'd be greaaaaaaaaaaat
Re: Went to the track again :)
they are mostly the round ones that fit on a flat peg. One like on the thermostat housing. Also I noticed on the stock TB there is a sensor that doesnt have a place on the 2G DSM Tb... Its the sensor that hits the knuckled of the throttle like tensioner when the butterfly valve is closed
