Intercooler Pipes
Old Nov 9, 2004 | 03:18 PM
TiburonWao's Avatar
Default Re: Java's Clearance Sale
Hi... Just want some help from you guys....
How many connections (breathers of the engine and intake) I have to build to the Intercooler Pipe that goes to the TB and the manifold???
Sorry..... I will try to get a picture for a better explaining.... oops.gif oops.gif
Thanks...
EDITED for "no DOuble Posting"
Spanish Version....
Saludos...
Necesito saber cuantas conexiones debo hacer en la tuberia que va desde el Intercooler hasta el TB y el intake??
Por ejemplo: Antes del TB, existen mangueras conectadas que van desde la manguera principal (la que va conectada al filtro de aier) y la pasan por encima del TB directamente hasta el intake
Old Nov 9, 2004 | 03:20 PM
Dweet's Avatar
Default Re: A little birdie just told me....
Old Nov 9, 2004 | 03:30 PM
alz99's Avatar
Vehicle: FX Coupe
Default Re: What is the best way to start with an automatic......??
airfilter intake pipe to turbo
turbo to intercooler
throttle body to intercooler
you can have as many or as few connections as you want.
i think thats what your asking?
TiburonWao's Avatar
Default Re: Intercooler Pipes
Ok.. Just found the Imgae.... This one is from Speed Factor
The parts where I talking about is all the Tubing before the TB
Sorry for DOUBLE POSTING.... I will Edit this...
Ok... In this Intake Pipe, theres coming 2 "air conection" 1 for the Engine and the other for a little bosch adapter over the Intake. Do I need to do both conection in the Intercooler "Up Pipe"??? Or I can conect does in other possition???
Old Nov 9, 2004 | 05:05 PM
Default Re: fuel filter
TIBURONWAO^^^
Now that I have your attention...
*STOP DOUBLE POSTING. USE THE EDIT BUTTON!*
