boost problems
ok first post here,2001 tiburon 2.0. i have the speed factor standard kit with a fmic, vortech fpr,tial 38mm external wastegate,and the krd manifold. first problem,
1.when i drive the car it runs, through first gear no boost , second gear small boost only 5 pounds ,when it runs right,then no boost after a hiccup that happens randomly arround 3 to 4000 rpms while under boost or not.or just cruising down the highway it will still happen.
2.turbo was boosting good after we left tims house(speed-factor)but it was still hiccuping. we had to drive it 200 miles home. the turbo is having problems spooling up now,and wont boost above 1 or 2 pounds.and has a weird metal against metal sound when rolling slow 1500 rpms slow acellaration sounds like a reverbarating sound but metal on metal.
any help will be appreciated please!
Vehicle: 2004 Acura TL
I've never heard "detonation" but that metal on metal in my opinion could be it!! What else do you have other than the VORTECH FPR to control your a/f ratio??
As for the spoolage,smile.gif I'd say you have a leak somewhere. I'll assume that the stuff was all new when you got it?? I'd check the wastegate, you may have that set too high, lower it and see if that helps. Maybe the manifold gasket went and you have a leak before the turbo.
I dunno man, tough one. I'm just getting my feet wet with the FI stuff.
First thing to do is check all your pipe connections, make sure no clamps came loose allowing a boost leak, pull on them hard since the may only leak under boost.
Make sure the vaccumm line going to the fmu is good and has no holes in it.
Check to make sure the vaccumm line going to the wastegate is connected and in good condition.
If those things look good you could have a bad turbo, the noise could be the compressor wheel hitting the turbo housing but that is kinda rare for a new turbo.
Guest
Posts: n/a
Well I know what is wrong with it, when he put the turbo on he didn't clock the center and had it sitting with the feed in the front and the drain in the back not facing down.
He drove it like that till he told me the turbo was dumping massive oil, and as we were going over everything that is when I found that out.
So what has happened is the driving it around like that destroyed the bearings and seals in the turbo.
Jon I will give you a call after I talk to my turbo guy tomorrow.
Make sure you don't drive it around like that, you could break the compressor wheel and send junk into the motor and you are allready, most likely sending metal dust into the motor from the metal to metal contact in the turbo, after that happens the turbo will not be repairable.
boost leak with the hoses? i have screw type clamps but there cranked down all the way.i checked them today. tim i never drove the car like that only started it twice for like 1 minnute to move the car onto the car dolly. then when i go to AZ. to park it shortly after i rotated the turbo as instructed and it was spooling great two days ago. on our way down to your house tim. check for me on the waranty. thanks for the reply the wastegate is set at 5.6 pounds. tim i also fixed the oil drain issue, we talked about when i was there.
