when should I put new clutch?
Old Nov 7, 2004 | 12:58 PM
OdessitPashka's Avatar
Default Re: Sleeper Project
I was wondering if our stock clutch would hold 5-7psi on t3, or should I put my clutch right away? I was thinking to put new clutch after I raise boost.
comments?
Old Nov 7, 2004 | 09:58 PM
captainSly's Avatar
Default Widest tire for our cars?
You can definitely run the stock clutch if you're not an idiot about driving it. I'm running my stock right now.... just avoid redlining and dumping it, you should be fine.
Always be into safeguarding though----look into a new one as soon as you can.
Old Nov 7, 2004 | 10:00 PM
Default Re: when should I put new clutch?
I drive normally until I get to the track, and already have a stage 3 clutch waiting to be put on, but since I will be taking my engine out this spring probably I thought I'd wait until then to do both things at once to make it easier.
