HKS BOV Fluttering: No Pshhhh
Hey my HKS BOV flutters instead of making the PSHHH sound. I can loosen the screw all the way and it still remains sealed. At 7 PSI some say that's normal, but when I read other posts of people saying that theirs stays open all the time I don't know what to believe. I hooked it up to the vacuum manifold that's hooked up to the brake booster line.
At full boost is gives off the short Pshhhhh but then flutters the rest of the way. This is why I felt there might be a problem.
Questions:
Is the fluttering a good sound...Is it safe...or is does it mean something else?
Is there a way to adjust it since my adjusting screw is all the way out, such as opening it up and clipping the spring.
Or should I just set it and forget it?
Questions:
hks make the To totototo... sounds they dont give you one solid pssshhhh.... they are a high pitch psh to tototo!!!
If you make a video we can say wither it is the Nature of the Hks of compressor surge!
