Kfx MAF to MAP ecu?
Old Feb 18, 2011 | 01:12 PM
JC01tib's Avatar
Vehicle: 2001 Tib1
Default Kfx MAF to MAP ecu?
Ok so here are my plans
I have a BetaII engine cvvt 20,000 miles out of a late 07tiburon . I ripped out my old wiring harness and ecu and currently in the process of installing the 07 harness and ecu
I have been looking heavily at turbocharging and when I save the money im going to build it on another Betta II
and i was wondering if anyone has used the MAP ecu From KFX http://kfxperformance.com/ixxocart/p...-2769-266.html
For there fuel management I'm not looking to go crazy boost just around 10-15 max or maybe even 7-11 psi
also I found where some said that the stock fuel pump will be fine for low boost but did not see any "MAX" on what the stock pump will do
Any opinions, options or direction welcome
Old Feb 18, 2011 | 02:08 PM
nos4atu's Avatar
I'll tell you the same thing I got told. "Save up and get a megasquirt, don't waste your money on that. You'll end up replacing it later anyway."
Also there are a few piggybacks out there that can clamp MAF voltage removing the necessity for a MAF. Or there should be something in the DIY section that informs what to do for a Beta swap.
Old Feb 21, 2011 | 10:10 PM
koreancorvette01's Avatar
Im running the KFX megasquirt, best investment EVER. Ive f'd around with all the piggy back BS, and this is the way to go better performance and drivability. plus guys like me can give you tunes that can help you get started.
Old Feb 22, 2011 | 09:16 AM
03tibe85's Avatar
Vehicle: 2003/Hyundai/Tiburon
I HIGHLY suggest you check your local emissions laws BEFORE you go with a megasquirt or any standalone for that matter. Where I live the testing station must be able to communicate with the ECU and not have any critical CELs. With a standalone you lose OBDII so you will not pass inspection in ANY state that requires it.
Old Feb 22, 2011 | 10:45 AM
turbosocks's Avatar
what he said ^^^^
with the perfect power and FIC piggybacks, they work GREAT and you can still pass emissions with the right setup like its not even there.
with standalone you lose OBDII which i would always want to retain regardless of emissions.
piggybacks are very drivable and don't make any adjustments from stock until you want them to. things with piggybacks and hyundais are a lot different than they were 4 years ago when you needed to run a dual fuel rail, injector driver crap, etc.
Old Feb 23, 2011 | 08:25 AM
Good point guys . Lucky me in MT, we dont have to worry about that, so that wasn't even factored into my decision making.
Old Feb 23, 2011 | 10:19 AM
Turboron_99's Avatar
Vehicle: 13 Gen Coupe Ult.
m Fic here... Zero drivability issues, no matter the temp. Runs great. Manages big injectors fine. Let you play with timing. Run 21 lbs of boost on a beta one, with a maf. And its a t3t4 50 trim garrett turbo. Car runs hard, never ran into any trouble.
Old Feb 26, 2011 | 10:05 PM
JC01tib's Avatar
Vehicle: 2001 Tib1
cool thanks for all the input , I don't have to worry about emission test where I live. unfortunately my circumstance put my turbo projects on hold but. the good side is I get more time crusting my eyes over, reading info and planing my build
so far i haven't found anybody that has used the kfx maf to map stage one or two .. and don't think i will be the 1st to try it ... unless its free
the 3 I'm mostly looking at right now is the
mega squirt (most likely)
haltech (frigging expensive)
or AEM F/IC (still reviewing)
